I am working on a small team writing an OpenCPI application. Have been through the OpenCPI tutorials where have to run commands such as:
ocpidev create project my_project --register
and other ocpidev commands to create applications, components and build and run.
But for a team of developers, running on VMs, how is it best to share a project? Should we simply create a single project, get that registered on each VM then just update that project? Or clone a new project and is there a way to register the cloned new files/project?
The term project is overloaded in this case. There’s is the Git project and the OpenCPI project. The way we’ve worked in our teams is create a new Git project containing an OpenCPI project.
Then each developer would clone the Git project and then register the OpenCPI project into their environment. We’ve clone them in the opencpi/projects directory but they can also live outside the OpenCPI tree.
Inside your new OpenCPI project , Project.xml, can specify dependencies to other project. For example, ocpi.comp.sdr project to access components and workers from other projects.
