HI all, I’ve come across a strange issue with the JTAG Support scripts where the commands given to Vivado via stdin (used in most of the existing OCPI JTAG related scripts) result in hardware manager being unable to find anything, yet if I convert them to get the same commands from a file it works properly.
For example this snippet from the jtagSupport_x310 script to find attached JTAG cables won’t find any thing:
$vivado -mode batch -source /dev/stdin > $temp.log <<EOF
open_hw_manager
connect_hw_server -allow_non_jtag
puts "BEGIN-TARGET-LIST"
puts [get_hw_targets]
puts "END-TARGET-LIST"
disconnect_hw_server
EOF
# Return the serial number (after final slash) separately as well as combined with the URL
CABLES=`grep -v "^#" < $temp.log | sed -n '/^BEGIN-TARGET-LIST$/,/^END-TARGET-LIST$/{//!p}' | \
sed -e 's^/\([^/]*\)\$^/\1=\1~^'`
if test $? != 0 -o "$CABLES" = ""; then
echo No Xilinx USB JTAG cables found using the Xilinx \"vivado\" tool. 1>&2
bad
fi
good
Yet running this practically identical version does:
$vivado -mode batch -source cables.tcl > $temp.log
bad
fi
good
Where cables.tcl is:
open_hw_manager
This is on Ubuntu 22.04 and the script used in the example is from the ocpi.osp.ettus project
Has anyone else come across this or have a suggestions as to a cause?
