Advice on using Xilinx Integrated Logic Analyzer (ILA)
Introduction
I’ve had some questions recently relating to the use of Xilinx Integrated Logic Analyzers inside OpenCPI HDL Workers.
I’m writing this as a current summary of what I understand on this topic. Worth noting, I do not have specific experience in use of Xilinx ILA, so I will be referring to what guidance is already available in various places, and using this forum post as a sign post to that.
If you have experience using ILA (or the non-Xilinx equivalents), and want to provide some additional advice, please feel free to reply to this post.
Current Primary Guidance
The primary guidance available relating to integration of ILAs is in the Debugging Tools Guide.
Section 3.1 provides two slightly different use cases on integrating an ILA core.
:warning: Warning
The guidance in Section 3.1 was written for Xilinx Vivado 2017.1.
There is an open issue on Gitlab that provides some further guidance on additional steps that are needed in newer versions of Xilinx Vivado (certainly 2018.3+).
This open issue links to a closed issue which contains a screen recording showing some of these steps in action.
Other sections of the document address Xilinx ISE and Altera SignalTap II.
Considerations for Specific Platforms
E310
The serial port on the external case of an E310 does not expose the JTAG connection to the FPGA.
If you wish to use an ILA with an E310, you will need to gain access to the internal connector to drive the JTAG port.
:memo: Note
I am informed that this internal connector is non-standard, but have not personally seen it.
The JTAG connector is soldered onto the board to a 3x2 1mm header. Using this will require soldering and a modified ribbon cable.
:warning: Warning
This will require removing the external casing of the E310, which you do so at your own risk.
Had to implement an ILA to debug a design I’m working on. Took some notes on the process used and would like to share here in case anyone is trying to do the same or at the very least I can reference in the future.
Configuration
  • Ubuntu 22.04 Host Development
  • Xilinx Vivado 2024.1
Steps
There are multiple ways to skin a cat. The current documentation explains a way to embedded debug core at the worker level. I’ve found it a little more straight forward working from the assembly.
  1. navigate to assembly / container-assembly-name-here/target-target-name/ directory
  2. source vivado environment by running ./tools/Xilinx/Vivado/2024.1/settings64.sh
  3. open .xpr file - vivado xprName.xpr
  4. open synthesized design
  5. using the schematic view mark the nets or signals you are interested in debugging
  6. on the left navigation bar under Synthesized Design click on - Set Up Debug
  7. follow the wizard and make sure each of the interested debug points have a valid clock
  8. save synthesized design xdc with debug info - use any name
  9. on the left navigation click on generate bit stream
  10. after bitstream is complete open up hardware manager
  11. program device using vivado , the nets selected for debug should be ready, set trigger
  12. run opencpi application normally using ocpirun and or aci to trigger execution of OpenCPI application
I’ll try to get this formally documented with screenshots and or video in the future.
